Central Locking Problems
shortyanddrums
I have a petrol 2002 avensis and the rear doors and boot (trunk) are deadlocked
The alarm and imobiler are fine and I can arm them with the keyfob no problem.
The dome fuse is fine as the interior lights are working in all cases I have changed it just in case.
I have changed the intergration relay but the symptoms are still the same.
The doors will not lock/unlock with the keyfob or the door switch.
The drivers side door will lock/unlock manually with the key in the lock.
The passenger front door will lock/unlock manually.
Any help would be great.
Also
Where is the location of the door control relay/what does it look like
Also
After several days opening and closing the doors manually, I accidentally solved the problem of the remote door lock/unlock in my D4D just by disconecting the car Battery to recharge it (probably you have to wait at least several minutes). After reconnecting, the keyfob was again functional. You will have to reprogram radio stations, set the time ...though but it may be worth it.
Also
tried to disconnect the Battery but still the same problem
hi there is a black box size of a 20 b&h located above fuse box unplug use some wd40 and plug back in should work if not u can pick them up 4 about £10 from breakers yard
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
