Alloy Wheels.
James Thor
Hi All,
Newbie here, and I need to replace the wheels on my 6th generation (1995) Celica GT 2.0. I'm considering buying some used which I've been told are off a 7th generation (2000) Celica GT-4. Would these wheels fit my vehicle? Do I need spacers or anything else?
Thanks in advance for you help.
James
Yes they'll fit. If they are stock Gen7 wheels, they'll have a 35 or 38 offset.
Great news, thanks alot! Yes I believe they're are stock, they are certainly Toyota. Do you know if I'll need spacers?
As edwardio says, the PCD is the same and spacers are not needed. If the Wheels are OE, 16" are ET39, 17" are ET38.
If they're after market Wheels, chances are you will need M12 x 1.5 60 degree tapered Wheel Nuts.
Also seen the below, does anyone know if these will fit?
Genuine
Toyota
4 x 16"
Wheel size: 16"
PCD: 5x114,3
ET (offset): 45
Alloy Wheels.
Tyre application for these alloys are;
205/55 R16 91V.
The part number for the alloys are;
PZ406-E8674-ZC,
FITS: SUPRA, PICNIC, CAMRY, AVENSIS VERSO, RAV4, PREVIA, MR2, AURIS, COROLLA VERSO, AVENSIS II ( 2.2 DIESEL), AVENSIS III, VERSO.
No, you must fit 5x100, ideally with an ET of 35-39.
Genuine
Toyota
4 x 16"
Wheel size: 16"
PCD: 5x114,3
ET (offset): 45
Alloy Wheels.
205/55 R16 91V.
PZ406-E8674-ZC,
They won't fit your Celica ever, but they would fit on my Camry :)
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
