Lambda Sensor 1.8
avfc
hi guys new here my mate has a avensis 1.8 2001 pltae engine management light onhe says its the right per cat brought one from euro car parts on his old one theres white tape on the new one blue tape but euro need toyota part number can anyone help plz
maurice
maurice
Maurice,
Go to toyodiy.com which has all the part numbers for your car. You need get you model code e.g.(AT221R-*****).
You will find the code on a silver plate on the passenger side door jam. This plate also has the chassis number, colour and trim codes.
Unfortunately the pictures have been removed from the site, but every part code is described and is easy to locate.
Once you have entered the model code you need to go to engine fuel, then manifold or exhaust.
You may need to note both part numbers, the site should describe what side the sensors are.
The other option is to go to your nearest Toyota dealer and get the part number from them.
Good luck and tell us how you get on. :thumbsup:
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
