Avensis T180 Diesel Estate
rossybrown
Hi all,
Newbie here, after runnng an alfa romeo for a wife I am lookng for a reliable(!) estate to replace it with and would love some feedback on potential roblems with the T180 diesel estate? I am going to look at a 56 plate with 70,000 for £6295.
Thanks in advance,
Ross
Hi all,
Thanks in advance,
Ross
Hiya Ross. Welcome to the forum... Is this the one advertised on eBay in Silver with red painted brake calipers by any chance? I've got a T-180 estate and one of the things you have to be aware about is a problem with over heating which leads to GASKET FAIL and a new engine like mine had.
Try and find one thats had its engine replaced by Toyota under warranty. Either a "short" or better still a "full" engine change. Avensis suffer from rust spots on the doors where the glass closes! So take a good look at the doors.
The EGR valves need to be cleaned out about 10000 miles or so. You can buy a new one off eBay for £130 with pipe if you take a look about. These normaly cost £300 from the main dealer.
Don't use anyother oil than Mobil 1 ESP 5w-30 (Castrol EDGE is not upto spec) in the engine! or you'll damage the D-CAT on them. The oil spec has to be "C2" so look out for that on the can. Amsoil do a geat one, but it cost £60 for the pot. So I'd get on eBay where you can get 10ltr for £60 delivered.
PM me if you want to knopw anymore about the T-180 D-CAT
Hope this helps
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
