2005 Avensis Bulbs
johnro
hello guys
i have a 2005 avensis and it seems that my tail lights are keep on burning (yearly i have to replace 2-3 of them)
do you have a list of bulb types for my type of car? (front, side and back)
i want to replace them with LED ones
thanks
hello guys
thanks
I have similar problem with my '08 TR. Replaced a rear one last week & got Mr T to do one front off-side today..
i) Didn't appreciate about LED ones being available - thanks...will order a pair today..
ii) I was stunned to find that after Mr T had done the front one today that the charge was only 43p (yes - forty three pee!!). He charges no labour!!! Amazing (explains why other charges are so high tho eh??)
PS And a free car-wash!! Well done Octagon Bracknell & thanks!!
hello guys
thanks
I think you'll find that LED lights are illegal to use on the public highway. They should only be use on show cars. I wanted some and went to Powerblubs for some Phillips LED sides. But it says in the small print that there not road legal...
hi i had the same prob with a diferent car and the issue was a water drainage pipe
losse meaning all the rain water was going into the lights compartement just needed
to resecure the pipe in its place. i dont know if apllys to this car but its worth a try
  • 9 months later...
Enter your car details into the drop down menu on the left hand side, and it will give you a list of all bulbs fitted to your car.
http://www.powerbulbs.com/
I got a difference of opinion from that site.....2005 Avensis T3S 1.8 is an H7 for dip/low and either an H4 or H1 for main depending which site you go on.....anyone shed any light as to which is the correct one please - the standard ones I have fitted are like small candles!!
ok I got this now.....H1 it is. Have just fitted philips extreme vision h7 to n/s light and the difference is quite obvious - much brighter, whiter and clearly defined. Havent had a chance to check it out at night as I'm waiting for my new o/s headlight to arrive - I figure changing the bulbs with the unit out will be easier than when fitted (unless I get my 4 year old boys and their small hands to do it lol). I'm gonna go with the philips extreme H1's so i'll keep y'all posted on how effective they are :-)
Just to be on the safe side I'm gonna get the adjustment done at my local garage so I'm not blinding ppl
