Fault Codes P0141 And P0161
kevinvic
I know that this subject has been covered before but as i need 2 rear sensors I am just wondering if there is an underlying problem. Could it be something simple as just a fuse? I am part-exing the car and need t get this fixed before I do. I erased the codes but obviously they have come back!! Was ok if I stuck to 30mph but as soon as I went over the dreaded engine light came back on. If it is the fuse, is it located under the dash with the other fuses and where exactly is it?
Kev
Both codes point to the usual heater circuit failure I'm afraid. Should measure about 15 ohms across the two leads (white?).
