Avensis High Level Brake Light
Rudster
Hi my 55 plate Avensis high level brake light has stopped working. I have checked the fuse box behind the glove box and can only see a fuse for stop lights which i presume is the standard two lights, this is fine. Can anyone tell me if there is a seperate fuse and if so where is it located ?
Thanks in advance.
Thanks in advance.
Hi Rudster, I have attached a diagram of the brake light circuit, it looks like it's all on the same circuit mate,hope this helps.
Regards Pete.
post-74463-0-24266300-1295552676_thumb.g
