Elm 327?
scott1212
I have ordered an elm 327 diagnostic cable with scantool version 1.3A, it should be here in next 2 days and i was wondering if anyone could give me hints on best way to use it or any tips as to get the most out of it as i have never used one before. Thanks, Scott.
the scan too software is a tad limited but it can read and reset codes and also give a sensor readout as well.
once you have the elm device connected to your laptop simply connect to the car and turn on the ignition and then click read codes. fairly straight forward.
you can get better software for the elm device but it tends to be expensive
Thanks for the info, i,ll post a reply and let you know how i get on when it arrives.Thanks.Scott.
  • 4 months later...
elm series products has 3 main product: elm 327 usb,elm327 bluetooth and elm327 plastic.
the best and expensive one is elm 327 usb.
the function about them are the same.
if you want to know more,you can go to esobd2.com to have a look.
I feel you need a software called OBD-II Software for elm327, in-order to communicate with the car PC. once you install it rest methods are simple. I am not aware whether there are other softwares available other than OBD-II.
