Did I Reset The Ecu Right?
Timewerx
After getting the engine to operating temperature by driving around, I pulled the 'EFI' fuse from the fusebox with ignition off, waited 1 minute, put EFI fuse back and drove off pedal to the metal.
Previously, the car was fully stock and used the not recommended, 91 octane fuel, it should've been 95. Recently, I gave it cold intake and switched to 95 octane. Performance boost was felt right away but...
...After resetting ECU post-modding/fuel switch, I only got very slight improvement in performance even after a 30 minute pedal to the metal drive. Is there something I missed? Car is a '96 Starlet 4efe engine.
