Rear Tyre Wear
guyfawkes1960
Hi to you all, Just had two new front tyres fitted to my 2006 Rav4 XT4 2.2d.
Both tyre are Yokohama Geolanders G91A, the rear nearside is the same tyre,
however the rear offside is a NS All-sport performance x/p which has worn
on the inside tread.
My question is why has this tyre so much inside wear? when the nearside rear is fine,
could it be the type of tyre, or something more expensive.
I'd first get the tracking checked - i tracking and camber - laser aligned is worth getting done.
Whats the mileage on the car? And does it/did it carry heavy loads/towing?
Maybe the tyres had been switched from front to bak at a previous tyre change? That may explain the inside wear
The milage is 52000, I have had the car for 12 months, it has got a tow bar fitted however I have never towed with the vehicle.
