Abs Mot Failure
killie
Hi
Not been on here for a while
Could do with some advice. Friend of mine has a 1997 Petrol Auto 3 door Rav4
One of the front Springs broke a while ago so he decided to replace the pair of them.
In the process of replacing the Nearside Spring, he has managed to break the ABS sensor on that side
it's the round switch that fits on the wheel. One half is still embedded and the other half is hanging by the cable
he took it for an MOT today expecting it to fail on one or two things. But the only fail was the ABS light on dash
The question is how to remove the embedded part we tried but it's not moving. Also do you have to buy the whole assembly or does the sensor on the wheel come as a seperate part.
Thanks in advance for any advice
Regards
Ian
You have to remove enough clutter to be able to drill it out. Some times if you use a small drill (1 or 2mm) and drill down the side, it will loosten the broken part.
It comes as a sensor with the lead moulded on.
Hi
Thanks for that. Would you have any idea hom much they cost ?
Regards
ian
Thinking back, i was somewhere around £86 for a front ABS sensor, that was October 2009.
