All,
I am looking to purchase an aftermarket fog light kit for my Dad's Aygo.
The car was built late 2009 or early 2010.
Could anyone guide me to reputable part sellers or particular part numbers please.
I require the fog lights (N/S and O/S) and also the steering wheel control stalk.
Although I am confident that between the two of us we could fit the system,
any member who can provide installation experience and/or instructions on the task
would be warmly recieved.
Similarly, do I require any other parts other than mentioned above?
I look forward to your responses,
Dan
All,
Dan
Pentagon sell the Toyota ones for circa 150 notes
There is no "stalk", you fit a plain rocker switch on the flat bit next to the key switch for the passenger airbag.
If you take a look at the AIM in the Toyota TechDoc website you can easily find the separate part numbers in there.
You need the wiring harness, the fog lamps themselves are cheap but the wiring is expensive. I fitted them myself and it took around a couple of hours, you will need to have the front of the car on stands or lifted up somehow to work underneath.
Here's the AIM I mentioned, couldn't link it before, as I was on my mobile...
LINK Right-click to download the PDF
benwiddowson: Thanks for the tip- pentagon have supplied all the parts necessary at a reasonable price.
Jan van de Wouw: Thanks for the manual - we commence the job in the morning!
CHEERS!
CHEERS!
What price did they supply them at? They were quoting about £140 fitted.
£140 fitted sounds like a bargain! I've just been quoted £134.26 for parts and £261.76 for parts and fitting!
Going to try ringing around a few more places soon.
...hope this will help! :)
  • 11 years later...
Update for the LINK Right-click to download the PDF
