Bloody Steam Clean
saxokiller
Hi Guys, I`ve just had my engine steam cleaned and now the !Removed! engine wont start!!!
I was warned this sort of thing can happen? but it ran perfect last night after i had it done then i`ve gone to it this morning and it turns over fuel is coming in but NO GO :censor:
Please help i need this car for work as well as pleasure.
By the way its an Ae92 Gti 1989
Max Respect The not so Saxokiller :crybaby:
hi,
i had a similar problem with mine when i had the car washed, water got in through the scoop, and car wouldn't start.(had just got the scoop fitted :thumbsup: )
i just dried everything up and cleaned the leads,it started up, drove it around for a bit got the engine hot and it didn't give any problems after that.
have you tried yours again?
before you steam clean or pressure wash cover the electrics with plastic bags and elastic bands
Its probably water in the plugs and ignition
Hi guys,wicked :thumbsup: Thanx for your reply`s ive had to take the day off to sort it and ive taken the dizzy cap off and found three of four posts inside the cap have disapeared so im thinking that could be some of the problem?! Lol
Max Respect Saxokiller :ph34r:
