Changing Alternator Plug Fitment . . .
Nathaniel
I have a 1994 ST202 2.0L 3SGE Import - which i believe makes it a Gen 6?
I have changed the alternator. the 'dud/broke' alternator that i have removed from the car has an 'Oval' plug socket. The alternator that i have bought, 2nd hand, fits like a glove although this has a 'round' plug socket - it came with the plug attached and 3 wires that had been cut.
I have cut the 'Oval' plug from my wiring loom, and attached the ''Round' plug using connectors, and then plugged it into the alternator but still The alternator doesn't seem to be working although 2 out of 3 of the wires matched due to colour. could the colours mean nothing hence needing a wiring diagram to ensure i have connected the correct wires together ? I'm not 100% i've connected the wires correctly. Could do with a picture from somebody's alternator showing the 'round' plug and which wires go into which pin.
I also have yet to do an alternator test, to see if i have bought a 2nd hand alternator which is also 'dud' :/
I'm not very mechanically minded, although i successfully changed discs and pads on the front and rear including rear inner shoes for the handbrake. changed both CV joints due to damaging them trying to get them out of the hub as they were severely ceased in. parts has been a nightmare and several trips to the motor factors. Just need to sort this alternator, Battery was new 3 days ago, but is now dead... need to jump start it and then hopefully it will charge via the alternator, once i can confirm the wires are correct.
Can anyone help ? Has anyone changed the alternator for another one which has a different plug fitment ? I think the original one i took off is Jap, and the one i have bought to replace it is Uk ?
Problem solved ! If anyone else has similar issues - i wired yellow to yellow, white to white and then the last 2 together following a diagram i found on the internet and using a volt tester. . New fuse and it's working and charging the Battery. Have now soldered the connections together as they were previously done with connectors. One very happy and charged celica :D
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
