I am in the process of replacing afront bumper on a 1992 surf. Can any one tell me if the whole front needs to come off
Hi and welcome to the club :thumbsup:
Could you please post any questions you have in the relevant section as this is for new members introductions ;)
Les
Hi there,
are you replacing the chrome bumper part, I'm guessing so as they are prone to rust?
If so the you will need to undo 2 nuts, 11mm socket I think, located one in each wheel arch in front of the tyre, they are in a recess - hence socket not spanner.
Then you can drop off the whole bumper and lower valance by undoing the big support bracket underneath the front - 4 bolts - 14mm spanner or socket I think.
If you have an A bar then drop that of first BEFORE the bumper, again 4 bolts - 14mm spanner/socket I think - oh don't forget to disconnect any spot light wires. The indicators should have enough spare wire to tilt the bumper/valance section forward and undo the connectors, before lowering and removing. Helpful to have a helping hand at this point.
The chrome bumper is attached to the valance by about 6-8 short bolts, again 11mm
I did my chrome bumper about 2 weeks ago on a 93 surf, took about 4 hours and I snapped about 3 rusty bolts, allow plenty of time and soak them in wd40 - if possible overnight.
Have fun!
