D4D Turbo Unit
rkdl28
Hello all. I need a new turbo system and have found a unit thats off a D4D Avensis however, I own a D-cat 2.0 Avensis and I was wondering if they are compatible? I expect they are but better safe than sorry! Many thanks in advance.
Have you com[ared the part numbers?
Not as yet. Suppose that should be my first action! Just wondered if the part was identical.
hello mate
in order to make a conclusion on compatibility of both turbos -- it is required to see the both engines particulars; fuel consimption; air delivery pressure etc. Otherwise you'll have a risk to overheat pistons + piston rings blocking + an extensive oil consumption etc. It is not easily to say yes or no but it is required a good learning. Cheers/Igor
Thanks for the replies folks. I've taken a number off my current turbo and I think(!) its 17301. Its very difficult to read and there are several numbers on a small plate bolted to the turbo. Is this the number I require to identify the unit?
Use www.toyodiy.com. Enter the VIN and find your turbo part number. After that you could choose a car by it's engine type to find the D4D turbo part number.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
