Problem Starting ( Battery ? )
Aishford
i dont know if any1 can help but i have a 2002 140 celica and recently if i leave my car for over half a day it struggles to start or wont start at all until i jump the Battery. I have had the Battery checked not that long ago and it was fine . if i go on a smaller drive for say half hour and turn it off n staright back on it fires up like a dream. Would this be the Battery or could it be anyfing else ?
Personally, I'd get the Battery checked again. If you do need a replacement, the pre face lift takes an 005, the face lift an 053.
HTH.
sounds like the Battery to me, the place testing it should be able to give you a percentage of Battery life, just testing it with a volt meter is not enough as you need to put load on it
