Gt4 St205 Suspension
Beanie
Hi all, and especially anyone who might be able to help
I've got a '94 ST205, which I've recently had to change the CV boots on, but since reassembling the N/S/F suspension, I'm experiencing a creaking/squeaking noise when driving along. As far as I know the fig 8's have been changed prior to my ownership.
Thanks in advance
Beanie
what about the lower arms? there is a joint on there as well. check for signs of corrosion in the joint as well, i have inspected a few where the joint has been ok for play but the joint had rust in and that was causing the noise.
also check the crush tubes on the rear arm
Thanks for the advice, will have to give them a check at somepoint. Although now the squeaking has stopped :S
on a semi-related note (namely because this went !Removed! up at the hands of my old man) are the ABS sensors handed or not?
dont think they are the same as they have different part numbers in the epc
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
