Starter Motor Problem?
notoriouscanary
My car (Avensis 2.0 Diesel Estate) won't start this morning.
When I turn the ignition key, the lights all come on (so I think the Battery is charged). When I turn the ignition key to the last position, I get a noise like a rapid continuous series of loud clicks ( I would say it sounds like somebody running a stick over a washboard) from behind the glove box. The engine does not turn over at all.
I'm guessing that this is a starter motor problem, but I know nothing about cars. Can anybody confirm, or be more specific about the cause of the problem.
Many Thanks
John
When I turn the ignition key, the lights all come on (so I think the battery is charged). When I turn the ignition key to the last position, I get a noise like a rapid continuous series of loud clicks ( I would say it sounds like somebody running a stick over a washboard) from behind the glove box. The engine does not turn over at all.
Many Thanks
John
if you turn your side lights on and try starting again do the dash/instrumnt lights go very dim.if so its a low battry or poor Battery connections,
Is that not the noise from a sticky dicky relay in the main fuse box behind, as suggested, the glovebox area?
Just a guess....
Big Kev :)
