Hi. might sound a bit thick but dont understand the speaker system in the mr2. normaly from the socket the wiring goes straight to Speakers but this doesnt seam to.is there an amp that needs to switch on as well,i have no radio in this car, just a socket hanging out
If you have the 'active' system then yes there in indeed an amp, which is loacted behind the passenger side rear quarter trim panel.
Easy way to tell is, if you have the subs in the cubby holes behind the seats, you have the active system.
HTH,
Mo
Speakers produce the end process -they change audio signal from electrical impulses to the sound that we hear, so they are of vital importance. With Speakers, it is imperative that you choose something that matches well with your equipment, your listening area and your listening habits. Speakers come in different shapes and sizes; Bookshelf speakers are more suited to a smaller space, but usually find it hard to generate the bass or power that floorstanders can.
____________________
VLC Free Download
