I have a 1991 Toyota Cynos and want to perform my first fuel filter change. I know that to change the filter I first need to depressurise the fuel line, but I just want to confirm that I know the right way to do it for this car. I figured that I would just need to remove the round EFI fuse and/or the 15A EFI fuse while the engine is running. Is this correct or is there a seperate fuel pump fuse somewhere that I'm missing?
thanks
You should not pull fuses when the engine is running. Pull fuses when the the ignition is off. Pull the Efi fuse and disconnect the fuel pump and start the engine until it doesn't start.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
