Rav 4 2.2 D4D 2006
robbo1979
Hi all,
I am new to this forum, but i wondered if anyone could help.
My rav 4 at first start up had very slow idle then when the throttle is pressed it was slow to respond.
so i put some injector cleaner in the tank and have been getting lots of black smoke. I have now used that tank of fuel and refilled and i am still getting lots of black smoke. It seems to happen when i let the car slow down then accelerate away. it also seems to be happening when the turbo kicks in.
not sure of next steps i do alot of slow driving around town as was thinking about putting some more injector cleaner in and taking the car for a good blast.
Hi all,
hello mate
1. what fuel do you use???
2. when did you change fuel filter?
3. when did you change an air filter?
4. SCV -check with their resistance and compare with manual;
5. are you sure the performance of your injectors is good?
I'd start from fuel filter.
CHeers//Igor
