Reversing Sensor
tanna
Hi, Can anyboday help? I have problem with reversing sensors which has stopped bleeping when you put in reversing gear on Toyota Corolla Auto. I am unable to find the switch in boot. Will be easy to replace (diy) sensors? I have been told that fuse might have blown but I don't know where would the fuse be, in the fuse box in the engine comparment. All help will be highly appreciated.
I have the same problem with my Avensis parking sensors. I've not had a proper chance to take a look at mine yet. But the switch in my car is situated in the boot under a plastic cover on the near side. I've been told that there is a white wire that leads to a fuse (blown) that is the most likly cause.
Hope this helps
Hope this helps
Hi, Many thanks for your help.
I just had look and I can see white wire going in lamps holding for brakes, lights but it is difficult to reach further upwards. Do you reckon that the switch or fuse might be around there? as I am unable to find anything. Once again thanks for your help.
Highly appreciated.
