1997 Avensis Mot Fail
boss100
Hello, I had the same last week on my 99 146k mile Avensis, emissions have always been high. I got the cat and lambda sensor changed and it passed. cat 70squids lambda 35 both from scrap yard.
hi i have a 1997 avensis and its failed its mot on emmissions high co level any one got any ideas
Hello, first of all check that the air filter is clean and that the spark plugs are ok. If these have not been changed recently do them as they are cheap, anything else starts getting expensive.
When you take the car for a re-test make sure the engine is fully warmed up, take it for a good fast drive first and maybe book it in for a while you wait job.
Good luck ... Pete.
The only way my old Polo used to pass the emissions test was to remove the air filter once I got to the garage and leave it running til the cooling fan kicked in. The tester got used to it after a couple of years and had a spot where people could put their air filters and bald spare wheels etc. Quite comical on a busy day.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
