Oil Filer, Spark Plugs, Pollen Filter - 7A Fe
peopleperson
Hello gents,
Does anyone know of where would be a best place to buy and whats brands people recommend for oil filer, spark plugs, pollen filter. Plan on keeping the car for the next 2 years.
Toyota Avensis
Year: 1999
Engine: 7A FE
146k miles
Thank you,
Hello gents,
Toyota Avensis
Year: 1999
Engine: 7A FE
146k miles
Thank you,
Hello, the "best place" to buy is the Toyota dealer for original parts but they aren't usually the cheapest!:D. Any good local motor factors can supply everything you need, brands like Fram and Blueprint are good makes.
Pete.
If you go to non toyota motor factors to buy cabin/pollen filters, make sure they are for right hand drive!
Mk1 Avensis is the only car where the filters are different for left or right hand drive, and some motor factors stock the wrong version.
The rest of the filters are cheap and easy to get.
I have used different brands of oil filters that are quite cheap. I change the oil twice a year. The air filter is checked and changed when needed. I mainly have used Fram for both air and oil filters with no problems.
Thanks t-spiritpete, Konrad C,
I have spoken with a dealer and he mentions this Avensis has two interlinking pollen filters? Am i wrong in thinking it only one filter as i've found one on http://www.thehappymotorist.co.uk/filters/filters2.php?vid=1421&Manufacturer=TOYOTA&Make=AVENSIS also the oil filter description is 80bhp when the vehicals 108 bhp?!?!?
pm Parts-King with your reg/VIN no & he'll give you a quote for genuine Toyota parts.
