Lowering
niksr
Is the auris t180 lower than a sr 1.6 auris even with the standard lowering springs? if so how much lower and could i lower mine the same?
I don't know for sure, but one possible way to find out would be to check the handbook for the height of your car, and compare it to the height of the other car. The chassis should be exactly the same, so assuming the wheels are the same size, the difference should be the suspension. Maybe?
