Side Lights ?
Rbdett
Hi guys just wanna no how many side lights you guys are going through this is my second set in 2 months I have tried led ones aswell but eventually they go ??
What can this be ?
My headlights are fine along with the other lights its just the side lights
You may just be having some bad luck but it seems odd. Even if you put a lower rated fuse in there the circuit should only deliver what the bulbs want to pull so there may be a fault that is causing the circuits to over load the bulbs and blow them. Wierd one.
Never had side lights blowing on me LED or otherwise.
I think Druid Boy is right.
mm, sorry but I'm still on the original sidelights on my 2007.
was going to change them for some whiter ones but couldn't get them out (we did manage to change the headlights which are generally considered harder to change so it wasn't for want of trying)!
When changing the side bulbs, I use a tissue and not touch the glass. Before that bulbs would blow after about 6 months or shorter. I treat them as I would treat halogen bulbs. It has been quite a while now since the last change.
