Celica St205 Chargecooler System No Answers Found
Billybobbooth
ok i have a mr2 turbo which is going to be running a the charge cooler set up from the celica st205
Im fomilliar with both cars well as have owned both but have hit a prob.
the celica wire diagrams only show the ecu pin out put and not what they go to, (please bare with me ill explain)
i have the wires from a celica 205 from both the wire harness from the pump and the ecu so can find the right wires by colour as i cant test the wires for power.
im using a mr2 wire harness with celica ecu and pump as i want to know if there is a prob with the cooling system for the pump so i know when to back off (my aim is safty not just bolt it up and run it!)
what im after is what wires go from the ecu to what wires on the pump and to the level sensor on the cooler,
e.g. ecu big plug wire black with thin white line to pumps solid red.
e.g. black wire on cooler to chassis earth with ecu small plug yellow to cooler red
so i can wire the car up so it all works rather than how it is now with not knowing if there is a prob,
thanks james
