Engine Warning Light After Cat Change
Geordieboy5
Good morrow fellow Toyota Fans. I have recently come across an issue with my 123k mile Avensis. It is a 2000 model 1.8vvti manual (That drinks oil). It recently failed its MOT on emissions......CAT was blowing. I replaced it and the clutch and it flew through the MOT......then the engine warning light came on. The garage said that the left bank of the CAT was out. I took it back to the Garage as the CAT has a 2 year warranty, and they fiddled with it....reset the ECU......and the Light came on again. Another thing has happened since I changed the CAT. I used to get 42mpg on AVG all the time.....now I am down to 36.9mpg. That is a significant drop. It has had the prerequisite oil/plugs/filters.....but it all changed when the CAT was replaced. Now as I am a tight @rse, I just got this all done at my local garage (whom I trust). Can any of you guys help?????
Cheers
That is a very distinct possibility. She goes through a litre every 1000miles easy. Is there anyway to check? The diagnostics (not Toyota) only show the left bank of the cat out of threshold. ????? I use 5w30, but am thinking of going to 10 w 40 oil to stop the burn so much. What do you think?
Well, if the car has done 123k miles, the oxygen sensors could be on their way,
even if the engine didn't burn any oil.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
