Diesel Yaris Engine Cut Out Problem
caroline4471
Fuel pre heater?
Probably all blocked up with gunge..
3 hours ago, TheHeff said:
Hi Folks - does anyone know the name of the part pictured below? It is attached to the fuel pump.By disconnecting it my car no longer cuts out and runs smoothly but when it is re connected the car will cut out after less than a mile. If I keep driving with it plugged out will it do any harm?
The name of the part disconnected is SCV and is the suction control valve.
Reading the workshop i have found this... i hope can be useful
  • 7 months later...
Hi garby , Do you know the spare code of the filter and for valve ?? Thanks
What filter and valve you intend? Where are located?
