Coil Wiring
aderiley
Seriously don't do it! You'll destroy your turbo instantly.
If your determined your best bet is to get a multimeter and test the wires yourself
currently getting boost creep in 4th and 5th, thought id cured it with a restrictor plate which has stopped the first 3 gears , i figure spark cut is better than the fuel cut im getting with the boost creep
Ah, was thinking it was for a Bee-r or something similar. To be honest mate your better getting your exhaust modified properly, I.e. A 2.5" centre section, then you can enjoy driving the car
