Lost Key
_naeem_
I have an Avensis 1.8 2001 VVTi and had two keys both of which are remote. I have lost one key.
Do i simply need to apply the 'All Clear' procedure as mentioned in the below link to remove all keys? Would my current key remain functional?
http://www.toyotaownersclub.com/forums/index.php?showtopic=119203
Thanks.
If you are not sure where you lost your key (which we expect) then use ALL clear to take that key off from your immobilizer.
Your master key will remain intact (unless you lost the master key and the one you have is 2nd) and you can program the further keys.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
