12S Caravan Wiring Manual Error
Dave228
Can anyone advise me if there is a mistake in the 12s wiring manual on page 44 section 28. Plug A3 has 3 wires which goes into plug C5 which only has 2 wires. It seems that the Red and Blue wire in A3 doesnt connect to anything. I am totally confused!
I am awar of the mistake with the fuse at the Battery terminal.
Solved - apparently it is unused on post 1999 caravans which now utilse a switched relay to charge the caravan Battery.
