Tramlining
howardm
Hi
Anybody experienced acute tramlining in a Rav.?
I have checked all the joints and found no play, tyre pressures are spot on, no sign of uneven tyre wear.
What else is there.?
Howard
Hi
Howard
Have you had the geometry checked, especially the 'toe angle'?
get it checked by laser alignment - maybe cost £120 but well worth it - I've used it a few times !
Not familiar with the term. What do you mean?
Anchs, remember when you told me about coming out of a tunnel in your train applying the brakes (wet leaves on track) and you carried on sliding for a mile, just missing the 4-10 from Paddington :lol: well thats TRAINLINING When i follow the Metrolink in my cab along Moseley St, (in Manchester) and my front wheels get stuck in the tracks and my cab wants to go in a different direction than i want it too :eek: well thats TRAMLINING :thumbsup: Stew
Like when your front wheels get stuck in the ruts that lorries have made in the road??
And when you do that on drugs it is MAINLINING (allegedly) :wacko:
Mike D
Mike D
So what is it you do with Coke, and a rolled up Tenner :unsure: Is that whitelining???? :eek: Stew
Try driving a 1936 Austin 7 Special if you want to know what tramlining feels like.
Its good fun though :thumbsup:
This is my other car.
http://i456.photobucket.com/albums/qq286/pgp001/Austin%20Seven%20OSU582/DSC04744.jpg
Phil
What a stunning motor Phill :toast: and stunning background as well :drool: Stew
Phil
Phil
What is under the bonnet?
Can you please have some photos hang right here?
Cheers/Igor
Oh right. No not experienced SEVERE tram lining. Has it got the original wheels and tyres?
Anchorman
It has got original wheels and tyres but not all the same size.
The fronts are 3.50 x 19" which were fitted on the earlier models, but I am running the later type 4.00 x 17" on the back which makes it handle a bit better ("bit" being the operative word !) The outside diameter of the tyres is the same.
I have started a new topic so as not to hijack this one.
http://www.toyotaownersclub.com/forums/index.php?showtopic=122139
Phil
Thanks for the input guys, I don't think its the tracking, but I'll have a look.
I am running a bog standard 3 door 4.2 2005 XTR.
Must be a rubber bush or something.
