Route Through Bulkhead
Installing some aftermarket front parking sensors. Looking for a convenient route through bulkhead for cables. Anyone any ideas? Preferably an existing gromit. Thanks.
When i fitted the electrics for my towbar, it tells you to use the existing grommit that the ecu loom uses.
It is located behind the glove box but easier to get to and see from the engine side.
There is also a spare port to push wires through, once you cut the end off it.
Hope this helps
