D4D Bad Starting When Warm
ron01
hi,
i have a 2001 rav4 2L d4d manual trans. starts fine when cold but after a journey and at running temperature if i stop engine for say 3 to 5 mins,(ie for fuel or quick pop into shop it has great difficulty in starting, just like a flat Battery. and has once failed to star and had to roll start it.
any ideas????
hi,
i have a 2001 rav4 2L d4d manual trans. starts fine when cold but after a journey and at running temperature if i stop engine for say 3 to 5 mins,(ie for fuel or quick pop into shop it has great difficulty in starting, just like a flat battery. and has once failed to star and had to roll start it.
any ideas????
hello mate
check with:
- Battery main contacts tightening;
- starter contacts + its primer solenoid contact;
- SCV contacts
It is understood all must be clean and tight.
I do not consider the Battery internal contacts -- cos i ve have had the same before with the same symptoms.
Cheers/Igor
cheers,
i have looked at Battery terminals and they are fine. having only having the rav 2 weeks at 130,000miles. it has full toyota service and in that i see its had 2 batteries and 2 starters so it has been a problem before.
i think the starting system would be under more stress and load when cold.
as long as the rav has been standing for at least 1/2 an hour when warm it starts ok.
i'm at a loss
does this throw any more light on it?????
thank you igor
cheers,
i have looked at battery terminals and they are fine. having only having the rav 2 weeks at 130,000miles. it has full toyota service and in that i see its had 2 batteries and 2 starters so it has been a problem before.
i'm at a loss
thank you igor
OK I 'd check with both SCV on the fuel injction pump body.
The engine temp influences on the SCV solenoid coil insulation resistance and may play.
I'd consider SCV issue when hot. Cheers/Igor
