any infomation on doing a turbo conversion to my 5e-fe ('92 corsa)engine??it cant be as simple as adding a set of GTstarlet pistons+manifold+ECU and a uni-chip???getting lots of diff. storys so any more info would be great.it only has to runlow boost as its going into an ep80. :thumbsup:
Check out these people http://www.poweredbytoyota.com/burientoyota/
They do a conversion kit. OK you will have to pay shipping from the states but its supposed to be an excellent bit of kit with good long term reliability. There is another option though. Apparently its possible to fit the cylinder head from the 3S-GE engines onto the 5S block so you end up with a hybrid 5S-GE . You obviously wont get the power of a turbo engine but you will have a totally reliable N/A engine with loads of torque and at least 180 bhp.
