Reversing Light Feed
apemandave
Hi all, is there any way I can pick up a 12v feed to the reversing lights at the front of the car to feed a monitor ( for reversing camera) without running it all the way from the back end ? Any help much appreciated. Great forum by the way. 2005 4.2 D4D XTR.
Hi.
There is a feed you could pick up from the fuse box, I think.
Is your reversing Camera wireless?
If not, you will have to run the video wire from the back to the front anyway, so may as well make life easier by running the video wire and the feed signal tapped off the reversing light at the same time (that is the way I did it anyway :P )
Yes its wireless, what would be the best rout to run the feed from the reversing light up to the dash? Thanks Dave.
