Fog Lights Bigger Than Holes
angel_capo
I bought a pair of leds fog lights, but I found a problem when I was going to install them.
The connector is ok, the same one, but the bulb is bigger than the original one, it doesn´t go through the hole, what can I do?
Where did you get it from? I bought my led set from autobulbsdirect and they fit fine.
There is nothing you can do, either make the bulb smaller our make the hole bigger.
Bought on eBay.co.uk
By the way, it´s like a stick full of small leds, impossible of getting rid of anyone of them so...the only way would be make the hole bigger.
I also found these ones
Mine are the same, I think I counted 40 each!
I think you should return them as they are not to h11 spec.
H11 only details the base on most LED bulbs. Either use a dremel tool to make the hole bigger or get smaller bulbs.
How often do you use your fog lights?
I can't remember using mine so far this year, so is it worth changing the bulbs over?
If these are anything like the ones I fitted to my old Renault, they are not as bright as normal Halogen or xenon bulbs, and are simply used for styling purposes.
