Rav4 1997
lonepiper53
Welcome to the forum.
The alarm immobiliser must be kicking in. Is the car Battery ok? That often affects the alarm.
If you do a search here, there are a few posts with comments about the early versions of the alarm system. It may be that you have a bad contact on the alarm sensors somewhere which set the alarm off....and activate the immobiliser. Any other symptoms before this happened??
