Brake Pedal Going To Far Down
HyperRain
Iv just fitted some new front and back ebc pads and now when i put my foot on the brake the brake padal is all most if not hitting the floor!! But befor i changed the pads it was no where near the floor when braking, anyone hve ideas??
Sounds like there is still air in the system, more bleeding required.
you have to pump up the pedal once your done changing pads, after pushing the pistons back in the calipers . if you've done this as mentioned system needs a bleed .
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
