Mid Roof Interior Lamp
alfadriver
Hi. I saw that the interior light in the middle of the roof was not working so I thought that I would change the bulb. I found that the bulb wasn't blown so I put it back. The contacts for it were crap but it fits ok and after doing this I found that the radio and trip computer doesn't work and the car won't lock or unlock with the key fob. Also, none of the interior lights work. The car unlocked and locked before I took the bulb out of the roof as well as the radio worked. Any ideas anyone?
checked fuse?
Yep, sounds like the fuse. The same thing has happened a couple of times on my one when I've taken the bulb out and replaced it. I make sure that I've got a supply of 7.5 amp fuses now!
