Brake Problems On Gen7 Celicas?
linty264
Hey guys, just looking for some info are there many people on here that have had problems with the brakes or any brake related parts on their celicas 99-2006 mines an 06 GT with 37k on it, new pads installed today and new rears last month, bleed valves not touched, just pushed back the piston with a clamp and installed pads, pumped up brakes and went for a drive just doesnt feel right. Do the seals or pistons give bother?
Plenty of problems with brakes, my 2003 vvti has just turned 60000 miles and I've replaced 3 calipers, all were sticking,and all 4 discs, all were rusting,the trouble is,according to my local dealer, I don't use it every day.I started this saga at 42000 miles with the front discs, 45000 n/s front caliper,52000 o/s front caliper, 57000 both rear discs, and last week n/s rear caliper at 60000. I'm now waiting for the o/s rear caliper to fail,the only one left that was on the car when it was new. the pedal is good though and it stops well enough.It has been annoying and quite expensive, but since I've had no other problems at all I've stuck with it.
U need to allow time to bed the pads into your old discs take it gor a bit longer drive applying brakes pedal should get firmer
