Timing Belt Or Chain...?
lestermester
Hello folks,
Does anyone know if a '52 plate Avensis Verso 2.0 VVTI (petrol) has a timing belt or a timing chain?
How often does the belt (or chain) need replacing? Unfortunately, I don't have a service manual to refer to.
Hello folks,
It has a chain and it will probably never need replacing.
Regards Pete.
Hello folks,
Regards Pete.
Hi Pete,
Thanks for your answer. Much appreciated.
Hello folks,
Regards Pete.
Agreed and confirmed. One reason why I like buying Toyotas.
i just changed my belt myself..
took me only about an hour fiddling around.. but you need a size 18 spanner with a long leverage (sleeve a scaffold pole over the spanner) and pull the tension pulley nut and the belts slips in and tensioned back to pull everything tight.
make sure you keep the Battery on, i disconnected my Battery as i was fiddlign with the alternator and i got bad idling with the first few days of driving because the ECU was off calibration and it took a day or 2 before it self adjust back to normal.
Thanks for the helpful replies. I like this forum!
