Hi guys,
I have a toyota Mark II '93, chassis GX 90, 1G engine... can i swap this engine with a 3sge one?? what about a diesel engine (2.4 2L-TE turbo-diesel I4)??? Cheers.
Hi and welcome to the forum.
I have never had any experience with the model you mention altho maybe its known by a different name in the UK - the 3sge and the 3sgte are both good engines.
The diesel? No idea - sorry.
thx a lot mate.....you cant find the car in the UK. Its the Local car for Japaneese people. Try wiki you may find it interesting. cheers
  • 2 months later...
Remove a 1G for a diesel!!!????
You can fit a 1G-GTE (pretty much direct swap) it's the twin turbo version.
You could also fit a 7M, 1JZ, 2JZ (all inline 6 turbo na or twin turbo varients found in supras) or a 1UZ-FE (4.0 V8)
are u just changing to cut fuel costs and is it a 2.5 engine straight 6 you have... :thumbsup:
There was never a 2.5 1G. You are thinking of the 1JZ.
  • 6 months later...
What is that engine model?First time to here that one.
  • 1 year later...
I have never seen anyone swapping 3S into Mark II, although their are good engines no doubt. But due to weight-power ratio, most owner around here would go for 1JZ-GTE instead.
  • 1 year later...
are u just changing to cut fuel costs and is it a 2.5 engine straight 6 you have... thumbsup.gif
I think diesel engine is better option, don't try to cut the fuel ever.
