Resistor Sea Airbag
MasherRav4
About to change my seats for ones that do not have airbag, anyone know where I can get hold of a resistor to avoid the airbag lihgt staying on ?
Welcome to the club.
We have an electronics guru called shcm who will be out proving Einstien wrong at the moment but when he comes back he is probably a good one to guide you. :thumbsup:
I'll leave that to very clever quantum mechanic physicists, who seem to have done a fair bit do discredit Mr E's "God does not play dice........" statement, although I can't be certain (QM Joke?) :unsure:
Squib simulation? Not something I've ever done. Not something I'm sure I'd want to do.....................
Anyway, do you know the squib resistance? I reviewed some airbag ECU designs long ago, but can't remember typical squib values. Would I want to try and measure it? :unsure::g: I expect the probe current from a DVM is fair less than the firing current, so I expect it won't go :blowup:
Resistors? On the high street, resistors from Maplin, I suppose (once you know what value you need). Otherwise, RS, Farnell, eBay, rapid electronics, my component stash.......................
I've recovered some old TVs which have a selection of resistors - you can have a job lot for nought !
