Fuse Problems
Stephen j
Hi there a little help needed, I have blown 2 fuses indicators and rear lights fuses 23 and 43 need help locating them if any one can help i would appreciate it, thanks for any help forth coming
Hello Stephen, I have attached a .pdf file with all the info you need for the fuses and lots more :thumbsup:.
Regards .... Pete.
RELAY LOCATION.pdf
You do not say what year your car is or whether it is petrol or diesel, there are some differences. 2003 + Fuse 23 is located in the in the long thin fuse box to the nearside of the engine compartment. Fuse 43 is in the fuse box behind the glove box.
Fitter
Fitter
Thamks for info i have now fixed problem.
Regards .... Pete.
Thanks for files very helpful, problem now solved
