Arb Bushes
600rob
When viewing a yaris is it possible to have a look at the ARB bushes on the car without the need to jack it up. Also where exactly are they under the car?
Ive had a look at a few vehicles so far but can’t locate the ARB. Has anyone got any decent pictures or diagrams of a Yaris under body so i can see exactly where the ARB bushes are located?
Thanks in advance
See http://www.toyodiy.com/parts/p_E_2003_TOYOTA_YARIS_NLP10R-AHMRXW_4803.html
Torch, overalls and kneeler required...About 40 cms inboard of front wheel attached to lower wishbone - protruding through bottom is a bolt head and nut...run to stabiliser bar which is a bar which runs across the car to the same arrangement on the other wheel...
Best use a jack .. and axle stands.
thanks for that mate, probly not one for when im vieiwng a car at the end of the day in my work clothes then. I'll best leave that for weekends.
cheers
French built and Jap built models have different bushes and part numbers, the link above is to the Jap spec so just check to ensure you get the right ones
Kingo :thumbsup:
cheers, for that parts king.
how can you identifiy & differentiate between a french build and a jap build vehicle?
By the chassis number, Jap buit start with JT1, French built start with VNK
Kingo :thumbsup:
