Avensis Engine 2001 Petrol
pascaloneill
is it safe to wash the engine of a 2001 avensis vvti petrol 1.6 if so what should i cover. if not what is the best way to dry clean it thanks
hi mate
the first thing to do is to install an engine protetor metal sheet underneath. secondly it is big risk to wash by water jet. i used to use a wet wipes for drivers and clean the engine once a month or two.
cheers/Igor
just to clean it and to see if their is any leaks etc in it was going to use a steam cleaner on it thank you both
