Rubber Plugs
bishop
I just bought a new 2004 Camry SE V6 Automatic. I found (2) plastic packages in the glove compartment each containing 2 rubber plugs #90950-01259. The packages are marked "IMPORTANT" "TO PRE-DELIVERY INPSECTOR: INSERT THESE RUBBER PLUGS INTO THE HOLES OF THE CENTER FLOOR SIDE MEMBER EXTENSIONS."
Should I have any concerns?
take it back to the dealer and make sure they show you the PDI check sheet if they havent fitted these what else havent they checked. dont worry they're just to keep dirt and water out of the rear chassis rails so its safe to drive without them
